Filled Region on Vertical Ductwork
BSchreiberAW4J9
BSchreiberAW4J9
Hello everyone. I was given a task and was wondering if anyone had any solutions. I was wondering if there was a way to assign filled regions to ductwork. So when looking at a vertical section of duct from top down it has a specific filled region. For example here is a picture of what I am currently doing to get around this problem. I was wondering if there was a way to make Revit do this all by itself without me having to draw a filled region to get the desired effect. If anyone has any suggestions that would be greatly appreciated. The picture on the left is what I need the ductwork to look like in order to get the correct meaning, and the picture on the right is what the ductwork currently looks like default from Revit.
RSomppi
Rise/Drop symbols are available here:
BSchreiberAW4J9
When I go into the type properties, I do not have an option for rise / drop as seen in this screenshot. Another question is can you create your own custom rise / drop symbols?
RSomppi
You need to be in Duct Systems and no, you cannot create your own.
