Good morning,
I would like to rotate this family to the angle of the roof.
It is possible to do this?
Thank you !!!
Solved by mpeperkamp. Go to Solution.
Hi @PS224358 ,
To give a correct answer we need to know if the family is face-based or generic.
If it is face-based then you can use the "Pick New" button to switch between the different workplane of faces.
If the family is generic you can rotate it with Rotate, provided that the family allows it to be rotated.
Maybe you can share the family.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Thank you for your answer.
I tried to rotate this one but i can`t do this.
Also with the Pick new host i can`t put it on the roof.
You can found the families via we transfer:
Thank you.
Hi @PS224358 ,
Thanks for sharing the families.
I loaded the families into a project and tested it.
The actions I put a video so you can watch that. If there are any questions let me know.
