Announcements
family not allowing section box to work properly
DJSCRIPTS
DJSCRIPTS
My section box wont wrap around my family in a neat fashion like it usually does. please see attached image.  What is the reason? Thanks,
Replies (22)
RobDraw
Do you mean "selection box"?
It works fine here.
Rob
DJSCRIPTS
Hey there. No, i mean section box. A 3D section box.
RobDraw
How are you applying it? Selection box command?
Rob
DJSCRIPTS
yes, with a section box command using auto section box addin
RobDraw
I said selection box as that is how I would create a section box that would "wrap around my family in a neat fashion" and it does when I insert your family into a fresh project.
I'm not familiar with that add-in, nor am I interested ATM. Good luck.
Rob
DJSCRIPTS
Yes, I know what the section box tool is. The one that is in revit currently was actually developed because of the the popularity of Autosection box addin. I believe I remember reading it was the most popular revit addin of all time somewhere. I am surprised you have never heard of it, its on the front page of the Exchange website under most popular addins. Autosection box actually pre-dates the section box tool in revit. but it calls the same command. It just gives you control over how far of a perimeter you want around the elements you have selected whereas the Revit one does not. But they behave the same otherwise. I get the same result either way.
RobDraw
I said "seLection" box.
@DJSCRIPTS wrote:
Autosection box addin. I believe I remember reading it was the most popular revit addin of all time somewhere. I am surprised you have never heard of it.
There are a lot of things that I haven't heard of. What makes you think I should be aware of it?
It's not the family as it works as expected for me. Did you test it in a fresh project? Did you test it without the add-in?
Rob
DJSCRIPTS
Yes, I know you said "seLection" box. But as I told you above, I am not talking about a "seLection box". To reiterate, nothing I am doing has anything to do with a "seLection box".  I corrected you on that above. Please forget about the "seLection box". It was only proposed by you, and has absolutely nothing to do with this topic. -->My section box is not working for this family.
Yes I believe this. I just meant that I was surprised because I've never met a Revit user that hasn't heard of Autosection box. And I was just surprised you haven't heard of the most popular addin of all time, meaning most revit {addin} users have heard of it. Nothing more.
It is unclear if you and I are even talking about the same thing. I have no idea what you were "expecting"
Yes.
Yes as I already stated above, "I get the same result either way." Meaning: I tried it with Autosection box, and I tried it without the Autosection box addin (by using Revit's built in section box tool), it doesn't work either way. In this project nor a brand new one. Therefore, there is a problem with the family.
RobDraw
Maybe you don't realize why I am focusing in the way that you are creating the section box. When I create a new project and create a section box with the selection box tool, the result is as expected, the extents of the family. This means to me that the problem is not in the family, otherwise, I would get a similar result as you.
What is different about your situation? Autoselection box add-in, maybe the problem is the way that particular family interacts with the add-in. As I test, I would remove the add-in. Create a new project and test.
Rob
DJSCRIPTS
Hi, yes I know exactly why you are focusing on the way i am creating the section box, but you are stuck on assuming too much and you don't seem to be reading my replies. You are quoting me but not reading what I wright. As I already said in my quote above that you quoted: " tried it with Autosection box, and I tried it without the Autosection box addin (by using Revit's built in section box tool), "... meaning i tried it both ways. You really think that an addin is going to change the way a hard-wired Revit command is going to work? No. So uninstalling the addin wont do anything to solve the problem. Have you made sure that you have all model elements and annotation elements turned on in your views when you create your section box? Because I do, and it doesnt work.
To make it even more clear to you look at the attached pictures. This is how I create an auto section box in "Capture" and in "Capture1" is how I make the section box. Neither one work.
Tighten up your reference planes extent in the family then the section (or selection, whatever) box will crop as desired in project.
RobDraw
Your second screen shot is Revit's seLection box tool. You were confusing matters by continually calling it the section box tool, even "correcting" me when I asked if you were using the selection box tool in your second post. I couldn't find a section box tool and actually thought I was missing something because of your incorrect terminology, TYVM.
And, yes, add-ins can change the way Revit behaves. That's why I suggested uninstalling it just to rule out the possibility, not that I thought it would be the cause but it does need to be verified.
Good luck!
Rob
DJSCRIPTS
I tightened up my reference planes and it did help a little bit. the section box is now at least smaller. But there appears to be something that is missing. See attached. this is the size of the section box that mine is creating for the same family. Are you sure you have all your model and annotation elements turned on in your view? Are the light switches turned on in your family? Thanks!
Kelsey.S
Autodesk Support
Autodesk Support
Hi @DJSCRIPTS,
It sounds like for this workflow, you're using the COINS Auto-Section Box add-in. Is that right?
If that is the case, I would recommend shooting a note to Coins support. They would be glad to help you out!
Cust. Support:
Please mark any posts that help with "Accept as Solution" and thanks.
Kelsey Skaug
Autodesk Technical Support
I turned on everything with a clickable checkbox.
DJSCRIPTS
Ok, two things, did you turn everything on in the visibility graphics menu as well? Also, I shouldve mentioned that I am in Revit 2018.3. I see you are in Revit 2019.
Kelsey.S
Autodesk Support
Autodesk Support
Hi @DJSCRIPTS,
I was following up to see if you got your questioned answered. If not, have you had a chance to reach out to COINS support to see if they can help?
Kelsey Skaug
fabiosato
I found out why it is happening, whenever you have nested families inside a host family, those elements are considered by Revit to be placed at the origin point, so when you create a section box it will include the position of the origin.
Fábio Sato
DJSCRIPTS
yeah I know, but I cant figure out which family is doing it. Did you find it?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
