Fabrication for Revit 2019 Plug In Missing
jdlandry504
Message 1 of 9
jdlandry504
First off if i am posting this in the wrong place, please let me know. I just recently got a new computer because my other decided to retire.  I have setup all of my software in the order that it should have been installed as well as run all of the updates for them.  I am missing the Fabrication for Revit 2019 Plug In.  It does not show up in the Autodesk Desktop app either. Is there a way to fix this?  The order i installed the products are listed below.
AutoCAD
Revit
Fabrication Cadmep
Navisworks Manage
Jason Landry
SM BIM-VDC Project Lead
ENFRA
Replies (8)
Message 2 of 9
Scott_D_
I've got this, I think it was found using the online Autodesk user account portal rather than the Desktop App.
I think its a new version as the old one didn't have the convert in place feature to change RFA's to ITM's.
Message 3 of 9
jdlandry504
I dont have access to our account management for whatever reason, so that's a no go route for me.
Jason Landry
ENFRA
Message 4 of 9
L-Vettz
You shouldn't need to access account management. It's considered a product update. You should be able to log in to your Autodesk account and get it here.
https://manage.autodesk.com/
-LV
Message 5 of 9
Scott_D_
That's the one, thanks L-Vettz.
Message 6 of 9
jdlandry504
Correct i misspoke before  I meant to say that i checked it and no updates show up.
Jason Landry
ENFRA
Message 7 of 9
L-Vettz
It should be there. Make sure you are in the Product Updates tab and use the search feature to look for "Revit Extension For" and you should get all the versions of the add in.Capture.PNG
-LV
Message 8 of 9
jdlandry504
Yea mine is blank. See attachment for what i see when i log in.
Jason Landry
ENFRA
Message 9 of 9
Scott_D_
I think you need to speak to your reseller.
