Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Exporting IfcSystem
3 REPLIES 3
WattsBL
163 Views, 3 Replies
Exporting IfcSystem
WattsBL
Observer
Observer
Hi All,
Can someone explain to me why when exporting to ifc using either schedules or user defined property sets file,the property sets assigned to IfcSystem don't export ?
Exporting IfcSystem
Hi All,
3 REPLIES 3
L.Maas
in reply to: WattsBL
L.Maas
Not sure what you mean with "the property sets assigned to IfcSystem".
If I am correct IfcSystem is just a value, a name for the system. So what you mean with property sets assigned to IfcSystem?
Other information that can help us looking for a solution:
-Which Revit version are you using?
-Which IFC schema are you using and have you tried others?
-Which IFC viewer are you using and have you tried others?
-Can you supply (part of) your project so we can see how you set it up?
-Have you tried the same with a small new project?
Louis
Please mention Revit version, especially when uploading Revit files.
Louis
WattsBL
WattsBL
Observer
Observer
I'm trying to export to ifc using the user defined property sets option (fig.1)
Fig.1
Below is a property set that i'd like to see on IfcSystem (Fig.2)
but as you can see from below only the revit property sets are exporting to the system not the user definded set
i've tried this option in multiple versions of revit 20,21&22 and exportin using the 2x3 schema for ifc. I've also viewed these files in 2 different viewers Solibri and BIMVision both with the same results
I've also tried this on multiple projects and some of the revit sample projects all with no luck
Fig.1
L.Maas
L.Maas
Try it like this and see if you get results then
PropertySet: COBIE_System T IfcElementType
If you want to have it more narrowed down, something like this:
PropertySet: COBIE_System T IfcDoor, IfcWall, IfcWindow
Louis
Louis
