Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Exporting a sheet from Revit to Autocad splits text to single lines.
9 REPLIES 9
Message 1 of 10
PEB73
962 Views, 9 Replies
When I export sheets to drawing files the text notes split into single lines. Is it possible to export so the text remains as multiline so it can easily be edited in Autocad? Is it possible to easily merge single lines from within Autocad?
9 REPLIES 9
Message 2 of 10
RobDraw
in reply to: PEB73
Yes.
Rob
Message 3 of 10
PEB73
in reply to: PEB73
And if so how?
Message 4 of 10
RobDraw
in reply to: PEB73
Can you show us an example?
Rob
Message 5 of 10
PEB73
in reply to: PEB73
Revit export does this where each line is in its own multi text box:
As opposed to this where all text is one box:
Message 6 of 10
RobDraw
in reply to: PEB73
How about what you have in Revit?
Does this happen with ALL text notes?
Rob
Message 7 of 10
PEB73
in reply to: PEB73
Appears to. I just did a test to see if it would work using a legend in REvit and exactly the same thing happens. Is there a setting in the export set up in Revit that addresses this?
Message 8 of 10
pkolarik
in reply to: PEB73
In autocad if you have the express tools you can use TXT2MTXT to change single-line text to mtext.
Message 9 of 10
in reply to: PEB73
DWG Export settings.
Message 10 of 10
PEB73
in reply to: ToanDN
Thank you that did the trick.
Forma Design Contest
