Export to pdf question
tawilson
tawilson
When I export sheets to pdf I usually give a look and sometimes want to make changes. I liked the way print to pdf kept the same file name and location when redoing, but it's usually slower than tar. With export to pdf, R22 keeps the same file name but changes the option to print current view, selected sheets, etc. R24 keeps the options to print current,,,, but changes the file name.
Is this in the program or are there export to pdf options I'm not finding?
fabiosato
You can try to use Pro Sheets from DiRoots.
Fábio Sato
Scott_D_
I have used Xrev Transmit for years, it remembers all your settings from the last set of files you printed etc.
AE_RevoBIM
I'll second this. DiRoots prosheets is the best PDF plugin for Revit and it's free.
A close second for automated batch printing would be RTV tools Xporter
jbowlesE4C6Z
No longer free, bait and switch, very volatile now.  PASS
jbowlesE4C6Z
Not free anymore, including sheets.
fabiosato
From Revit 2024, export PDF has some improvements, they may fit your needs
Fábio Sato
