Announcements
Export to DWG
Export to DWG
Hi All!
I am having trouble with colors while exporting Revit files to DWG, especially when I have linked architectural background inside the Revit file.
The thing is that in my export settings detail items are defined to export as color Nr. 92 (see below)
but when I export it without architectural link, detail item (arrow on grill) becomes black. Even bigger problem occurs when I have architectural link inside the project, then all the details (and hidden lines) become red. What is defining the color of detail items if not export settings? Why is that arrow without architectural link black (color Nr. 250) and with architectural link is red (color Nr. 10)?!
Best regards, Branimir
Hi Brane1012,
First you have to update your Revit Software. Now is UR13.
After that please follow like images below:
An example in Revit like this:
Modify setting DWG like this:
In CAD after export:
Thanks.
jtgel
 Revit should have an option of exporting Exactly what you see, In other words all colors would be the same or at least real close.
