Export settings vs Object style
silviobrother
silviobrother
Hello to all,
Could you please help me on the situation described in the attached file?
Thank you to all.
hmunsell
2 things...
if you change one number and all the subcategories change, that is because the layer descriptor column are all set to the same layer. the subcategories need to be named differently so they export on different layers.
another thing to check is... if your are sure all the export layers are correct, it may be the Export Layer Options setting. you may have overrides applied in revit that are being not allowing the export table to set the elements correctly.
Howard Munsell
silviu.bunu
Thank you hmunsell for the solution.
hmunsell
my pleasure.... glad it worked.....
Howard Munsell
