Export RVT to DWG
Export RVT to DWG
o.pellegrin
Export RVT to DWG
o.pellegrin
Hello everyone, I am trying to generate .DWG files from .RVT model. In my revit model, I have dozens of different families with specific attributes coming from shared parameters from the project. When i show the properties of my blocks in autocad, I can't see the attributes of the family in Revit. I would like to know if it is possible to export thoses parameters in my .DWG objects so I dont lose equipements information from 3d to 2d. thank you
L.Maas
No these are two totally different software programs so most of the parameter data will not pass over to Autocad.
I know that when Revit epxorts to Autocad it also export some data as xdata. So it might be possible to write and add-in (or already available?) that exports additional data to xdata.
Louis
Please mention Revit version, especially when uploading Revit files.
Louis is correct here. I have done a LOT of passing DWG files between AutoCAD and Revit over the last few years and there just isn't a direct way that I know of to get family parameter info into AutoCAD blocks as attribute information.
o.pellegrin
All right Thanks for your answers, I'll keep looking. I think there might be a way to do that with Dynamo, I'll look into this. Cheers
