Export duct/pipes to xml
Im trying to export my duct and pipes to a xml.
How can I do this? Do I need a addin?
I like to hear youre response!
Kind Regards,
Jan Willem
dgorsman
XML is a generic file format, it can be used for nearly anything e.g. LandXML, Navisworks settings, AutoCAD tool palettes.
What schema are you trying to work with?
Yes, I know. I need to make a xml how can I do that?
I'm trying to make an xml for the prefabrication.
HEETESHC
Hi @Anonymous,
You can export an XML file from Revit model. You need Navisworks Plugin of the same version of Revit you using.
(Note: Version means a year of Revit like 2016, 2017, 2018, 2019 like this)
Thanks for youre reply.
I use navisworks and I know what you mean.
We will make a xml from my duct and pipes to send it to the factory of the manufacter.
The xml needs to be a xml like image below:
deheerJ.Nieuw01
Observer
Observer
Goedemorgen Jan Willem,
Is dit al gelukt ?
Ik ben wel benieuwd want ik zoek ook zoiets.
Met vriendelijke groet,
Jos
