Error when importing dwg
I have an error occuring when i'm trying to import a dwg.file to Revit.
Do anyone know why this is appearing and how to fix it?
I can import the architecture dwg files, but not mechnical, electro and etc.
jrobrador19
Hi there,
The reason might be the name of the file has too many characters and combine that with the location of the file. Try to rename it with lesser number of characters or copy it to a folder with a shorter file directory.
I hope this helps.
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified InstructorRevit Architecture Certified ProfessionalRevit MEP: Mechanical Certified ProfessionalRevit MEP: Electrical Certified ProfessionalInventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
