EnergyPlus simulation did not generate a report for systems analysis
ktataaymen97
ktataaymen97
Hello everyone i had an issue for generating reports of systems analysis ( Revit 2022) ,i tried it for a lot of models and always shows the same message "EnergyPlus simulation did not generate a report for systems analysis". I used the same model from here https://www.autodesk.com/certification/learn/course/revit-system-analysis-mechanical-design-professi... and it doesn't work .
iainsavage
There is this help page:
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/CloudHelp/cloudhelp/2021/ENU/Revit...
...and there is this post below. I am still in contact with Autodesk support on this issue and they are working with NREL to try to find a solution:
https://forums.autodesk.com/t5/revit-mep-forum/system-analysis-2022/m-p/10909788#M83850
mromagnoli
Dear community friends;
Dear friends of the community, finally I found a very simple solution to solve the error "EnergyPlus simulation did not generate a report for systems analysis" and I want to share it with us.
Simply put, it is an update to the OpenStudio that Revit uses to process all Energy Analyses  🤔
👉Watch the following video for more details - https://youtu.be/jUtnFJKwHzE 👀
If you found my comment useful or it was the solution to your problem, give it a Like and Mark it's a Solution!
Best wishes! 😎
Arq. Marco Romagnoli
AutoCAD Certified Professional | Revit Certified Professional | 3Ds Max Certified Professional | Fusion Certified User | Autodesk Certified Instructor | VRay Certified Instructor
biruk_workneh
I found a similar YouTube video with an English commentary.
