Calculate total true load in panel schedule
Mahmoud_ElNahas
Mahmoud_ElNahas
I am trying to calculate the total true load within the panel schedule but the issue is power factor is vary between circuits. I know it will be calculated if the power factor is consistent by Calculated Value (total connected * power factor) or by scheduling the electrical circuits and get the total true load calculated.
Any chance to get the same result for various power factors in panel schedule?
fabiosato
In Electrical Settings you have these options:
Fábio Sato
Mahmoud_ElNahas
I tried it already but it doesn't work as the demand factor still 100% as below
fabiosato
To change the demand factor, in each load you must select a proper Load Classification.
Fábio Sato
