Energy Plus Heating and cooling load Analysis Error
Message 1 of 9
Energy plus simulation didnt generate the analysis - This is the error that i get. Even  if i  try to visualize in Insight i am not able to generate it i have tried different locations but no results
Replies (8)
Message 2 of 9
Hello, do you made any changes in the Construction material? if changed try to use Default materials from the Revit itself.
Message 3 of 9
i made the changes and gave specifications for the walls and roofs.
Message 4 of 9
Please check this attachment, if you done any modification try to keep default and try the Calculation again. if it is works change one by one review the calculation.
Message 5 of 9
No its not working for linked model.
Message 6 of 9
erik_snell
Has the energy model been successfully created? Have you setup your Analytical Systems or are you using the default?
Autodesk Logo
Erik Snell, P.E.
Experience Design Architect
Autodesk Revit
I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
Message 7 of 9
lonelanrete
I also have same problem.
Energy model OK
Insight 360 OK
Heating/ Cooling Load OK
System Zone setting already follow best practice https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-A9F31524-C777-487F-B731-6DACB532B13E
but system analysis always shows error
2020-05-13 (15).png2020-05-13 (16).png2020-05-13 (17).png2020-05-13 (18).png
Message 8 of 9
enriquesissa
Same here. Any fixes?
Message 9 of 9
ceyhunyuzuak
as I commented in some earlier post:
give spaces numbers AND names and then try again please.
if it doesn't work you might want to consider to share the .rvt file so we can take a look.
