Energy Plus Error Analysis
lorenzomasottiarchitetto
"EnergyPlus simulation did not generate a report for systems analysis."
When I moved to the  temp folder into "run" of the last Revit Analysis the message is always this...[openstudio.workflow.OSWorkflow] Found error in state 'OpenStudioMeasures' with message: 'Errno::EINVAL: Invalid argument - //lib/ruby/gems/3.2.0/specifications/default'
I tried to follow the on-line guide procedures find at:Help | Revit Error | EnergyPlus simulation did not generate a report for systems analysis | Autodesk
or.-Help | Energy Simulation Failed | Autodesk
I didn't find anything useful even google it when across to gifthub report. Anything had the same issue?
iainsavage
There was also, when they first released it, an issue with incompatibility of the CPU with the command line version of open studio.
https://forums.autodesk.com/t5/revit-mep-forum/systems-analysis-not-working-quot-energyplus-simulati...
As far as I know that was resolved but I am no longer able to test this due to lack of the required licence.
Hi @iainsavage , Hi rebuilded the folder of OPEN CLI- REVIT 2026 with the asset from te Open studio Web-site- which contains more updated files. In opposite, I would say that if It doesn't close with the Energy plus error, as said to you before, it doesn't perform until a result anyway. I left my PC working all the night and, when finished, the calculation in background, it definitly didn't produce anything.
Any possible answers?
iainsavage
As I said I can no longer run the analysis so someone else will need to help with this topic.
