Enable to see my drafting views in the project browser in Revit 2017.1
Message 1 of 24
Something strange is happening in my model. When i create a drafting views it open's but doesn't appear anywhere in my project brower. Before you ask, iv'e look at te properties of the project browser (filter, regroupement, etc..) nothing there...normally in 2016 these drafting views appears in the ??? catégorie but not this time. Very strange...
Somebody already experience this issue ?
Replies (23)
Message 2 of 24
RobDraw
Do you have a view template for drafting views that is set to be applied to new views automatically? If so, that template is categorizing it for you.
Rob
Message 3 of 24
Someone probably altered your project template so that newly created drafting views are automatically assigned to a discipline.  Look at the Discipline & sub-discipline properties of your view.
Message 4 of 24
I have no view templates associate with new drafting views (i think it's not possible for this kind of view) ...or else where would it be ?
I know you can do it for floor plan, and ceiling plan but not drafting views, maybe i'm wrong.
When i start a new project from scratch my drafting views appear in dark black in my project browser but not in my project and i don't know where i can find the solution to this issue.
Thanks for your help.
Message 5 of 24
I can see my drafting views properties when i create a new view. The discipline is Coordination by default, but even if i change it ...it still doesn't appear in my project browser.
Message 6 of 24
RobDraw
You can assign a default view template for drafting views. Go to a drafting view and check the type properties.
Rob
Message 7 of 24
RobDraw
Have you checked the sub discipline?
It should be very simple to see your view. Have you expanded all the categories in your project browser?
Rob
Message 8 of 24
Hi, yes i did ..the Discipline is Coordination by default and the Sub-Discipline is empty. But in my project browser i set the option to "all" ....what should show me every view in my projet. But none of my drafting views appear even after expanding every mark. I really don't know what's going on. I never saw this. I'm the BIM manager at my office, i also am an Autodesk Certified Professionnal en Revit-MEP electrical. I totally understand what your trying to tell me but for some reason, it seems to be hidding my drafting view whatever the project browser is setup.
Like i said the only way i can figure that my views are being created is by a Schedule.
Thanks for your support.
Message 9 of 24
RobDraw
Can you upload an empty project that exhibits the behavior? I will take a look for you. I hate guessing games.
Rob
Message 10 of 24
robert.klempau
Hello @Anonymous,
If you set your Browser Organization of your Views to All, do you see your Drafting View then?
If Yes, Check if there are filter settings in your previous Browser Organization
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 11 of 24
Hi, yes i set my project browser to all but still can't see my drafting views. There is no filtrer as well.
Autodesk is on the case, but still nothing yet. Very strange.
Message 12 of 24
robert.klempau
Hello @Anonymous,
Ok, if Autodesk solved your case, would you be so kind and share that with us?
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 13 of 24
Hi everyone,
I FINALLY FOUND THE SOLUTION !
A good way to resolve this problem is to simply open a new project that doesn't have the problem in the same Revit session that our corrupt files your presently working with.
You create a new drafting view in the new projet. In the project browser, you right clic and copie in the press-paper.
You switch to your corrupt files and paste your drafting view that you just copie with the "paste" option.
Voila ! The drafting views now appear in the "???" categories in your corrupt files, or project files, or custom templates.
And that's it ...it was that simple !
Thanks for everybody that took time to help me. Really apprecitate.
Cheers,
-Bruno-Pierre-Caron-
Message 14 of 24
RobDraw
So, your file was corrupt? What makes you say that?
Rob
Message 15 of 24
Well it was "corrupt" in the term that i wasn't able to see my drafting view in the project browser.
Not corrupt in term of error message.
Message 16 of 24
RobDraw
So, how did you come up with the solution and what does it do to fix your browser?
Rob
Message 17 of 24
I started a new project from scratch and create a drafting view and found out that it was working. So i right clic on it to copie and paste in my other projet that i was enable to see my created drafting view.
And when i paste my copied view...it ask my to overwrite some "generic" information bases on the sub-project "view" that is integrated in revit system.
And that corrects the problem..hope you understand.
Thanks.
Message 18 of 24
RobDraw
That "generic" information is the key. What was it that you were missing?
Rob
Message 19 of 24
robert.klempau
Hello @Anonymous,
Great that you solved it.
Do you think it would be solved if you opened your project and checked the Audit checkbox?
Do you have a backup file where the problem still exists?
Would you be so kind and test that for us?
I am curious if the Audit will fix the problem.
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 20 of 24
Hi @robert.klempau
I did make a test with the audit box check in, and unfortunately it did not correct the problem.
Like @RobDraw said the key is in the "generic" information" relied to the view sub-project properties.
Can't tell what exactly was overwrited but that corrected the problem instantly.
