Elements are only showing correctly when panning or zooming
Hey,
Just wondering if anyone has come across this before. Basically the first screenshot below is of some pipes running below a duct, however as you can see, the parts are still partially visible even though they are underneath. The second screenshot is of the exact same area but is when i'm panning and it doesn't show the pipes which should be what happens?
I don't believe it has anything to do with my graphics card because when I print the drawing it shows the pipes like in the first screenshot.
Does anyone know how to fix this issue?
Thank you
RobDraw
I'm not following your question. Do you want the hidden lines showing or not?
If not, you can turn them off globally by unchecking "Draw MEP Hidden Lines".
Rob
Yeah sorry, didn't word that too well.
Knew it was going to be a simple fix, thank you!
