Well as you can see the connection of my electrical plug goes to the origin point. The electrical connector is in this family that is hosted in the main family of the plug. I'm using revit 2019 version, in revit 2016 this problem is not experienced. I would be glad if someone could tell me how to solve this in revit 2019.
Solved by jill_chen. Go to Solution.
@Anonymous Thanks for the feedback, could you share the family that you mentioned, we did some fix in r2020, hope that's cover the problem you mentioned.
https://drive.google.com/drive/folders/1DMxDURMhOKb0fAFd_4tjI90xlx9zjsdQ?usp=sharing
Here it is. I'm going to download the newer version of the program and see if it solves the problem. Thank you for your support.
