Elbow not change in pipe size during Slope creation
i have created a Revit family for Elbow (90deg & 45deg) in different pipe sizes. And after slope apply in project, not change pipe size. Please see the image file.
please help any solution.
K.Mano
RobDraw
It looks like there is insulation applied to everything but the elbows. If the elbows were not changing size, I would expect a reducer on either side of the elbow.
Rob
kadmonkee
as @RobDraw suggested you will need to edit the family to add insulation
if you tab select a piece of pipe all the connected Pipes will be selected and you can add insulation to all of them at once.
if that does not work then your family may be broken - as far as insulation goes
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
