Just to state, I currently do not have access to Revit 2015, so I cannot view your actual file.
From the look of the array of Yes/No Parameters (indicated by the checkbox), the Family is set up in a different and much clunkier way. My assumption is that each one of those Yes/No Parameters corresponds to a Family Type of the loaded Generic Annotation Families. If this is the case, then a single instance of EACH of those Families must be placed in the Ref. Level View in the same location, overlapping each other. Then, each of those elements' Visibility Parameters will be linked to the corresponding Yes/No Parameter, which is done by selecting the annotation symbol and clicking on the small gray button beside "Visible" under Properties. (The easiest way would be to place them scattered around at first, link the Visibility, and then move them into place.)
The more streamlined method of accomplishing this would be to use the <Family Type...> Parameter following these steps:
1. Load the desired Generic Annotation symbols into the host Family. More can always be added later.
2. Place one instance of any of those Generic Annotations in the Ref. Level View.
3. On the Family Types dialog, add a new Parameter named "Annotation Symbol" (or something similar), leave it as a Type Parameter, and change the "Type of Parameter:" to "<Family Type...>". From the following list, select Generic Annotations. You can assign any Group that you wish to this Parameter. Close the Family Types dialog.
4. Select the instance of the annotation symbol that you placed in step #2. At the bottom of Properties, change the value of "Label:" to the name of the Parameter that you have just created. If a warning dialog appears, just click cancel and ignore it. The element is now linked to the newly created "<Family Type...> Parameter.
5. Open the Family Types dialog again. Now, you can assign a specific Generic Annotation to display for each Family Type by assigning the desired value to the newly created <Family Type...> Parameter. Simply use the pull-down list to select the appropriate Generic Annotation Family for each Family Type.
Corey D.
──────────────────────────────────────────────────────────────────────⁞|⁞ Please use
.Accept as Solution and
Give Kudos as appropriate to further enhance these forums. Thank you!
