Dwg export
Dwg export
Dwg export
We are trying to import Revit into AutoCAD and a default page setup to be 24x36. I have created a .dwt file and pathed all folders to that .dwt location. Each time I export the file from Revit it creates a .dwg with the layout1 page setup at 8.5x 11. I want it to be 24x36. Does anyone know if there is a different location where Revit or AutoCAD pulls template files from?
RobDraw
There is no way to assign a .dwt during export.
If you are exporting a sheet, the size is determined by the sheet size in Revit.
You are going to have to insert the exported .dwg into a new .dwg created with your .dwt or if all you need from the .dwt is the layout then you can import the layout into the exported .dwg.
Rob
