Duct offsetting transition Fitting
advandes
Advisor Advisor
Message 1 of 10
advandes
I have messed around with this for some time now and can't figure out if it's possible to create a duct transition that is neither eccentric or concentric on any side. For example: See attached views with annotation lines representing what I want. Thanks for any help!
AAG
Advance Design
Replies (9)
Message 2 of 10
Scott_D_
You can use model in place, select the duct fitting category and put connectors on it. You could also make a custom family that is a blend and turn the geometry sideways.
Message 3 of 10
Hi.
Usually i create a small duct stretch on out of the equipment and align at position i want to connect the both ducts.
I made a screencast to explain.
I hope helped you.
Message 4 of 10
RobDraw
Revit can make that fitting automatically. It may take some trial and error to get it right. Draw the ducts on either side and set there locations. Then connect the ducts. If it doesn't work right, undo and try it in a different type of view.
Rob
Message 5 of 10
Thanks Jorge for sharing this video..
Message 6 of 10
advandes
I can't believe how easy that was. Thanks!!!
AAG
Advance Design
Message 7 of 10
Hi all. I'm Dat from VietNam. Can you help me about library REVIT MEP for ACMV Systems?
Message 8 of 10
dsmith
Observer
Observer
Message 9 of 10
dsmith
Observer
Observer
This did not work for me in any view I tried. I just kept getting invalid routing errors.
Message 10 of 10
RobDraw
Did you check the routing preferences to make sure that they are setup correctly?
Rob
