Assigning thermal properties to inserted components
I am trying to place a piece of equipment (for example a Biofreezer) in a room that I wish to perform heating and cooling load calculations on. Is there a way to insert a component AND give it thermal properties like the dissipated load in BTU/hr and have Revit account for it during the heating and cooling load calculations?
Scott_D_
You can only account for heating loads afaik.
Have a look for a post by Martin Schmitt on the subject in the thread linked below for a workaround:
https://forums.autodesk.com/t5/revit-mep-forum/revit-mep-space-schedules-actual-heating-load/td-p/29...
Hi.
  • You need to enable Spaces calculations in the Manage> Mep Settings> Eletrical Settings> Load Calculation> Run Calculations for loads in spaces
Like on image.
You can configure the loads on this page as well.
  • The Family must have a power connector;
 And when clicking on the space you must select the "Current" option in "Eletrical Loads";
I hope I helped you
Best regards.
