- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi dear Revit colleagues,
I have a real life case study to propose you in Ventilation.
I join you a Revit file with a supply air (in blue) et Return air (in yellow) connected to an AHU with two external Cooling coil.
The problem is I have a lot of "Cutting" flow transmission and I can't find why.
I realised some previous project with 3 stairs offices building ans it was working well.
In addition of the revit file (2020 version) I add some Screenshots to show the problem in preview.
In the Revit file you can open the 3D view "Case study".
1/Overview with theorical flow data I'm waiting
2/ Table of flow system:
in yellow: The sum of the air terminals, this is correct
in green: Correct in the Mechanical equipment
in Red: Wrong value
3/ Duct System Error
4/ Duct flows given by revit tag.
Some values are lost after elbows.
5/ The value is equal to 0 in the duct, but after in the Sound attenuator the value of my shared parameter display the expected value !!!
Thanks a lot if you take a small time to find something bad in my design.
Yoann
