Dropdown list in Project Information and use in TitleBlock
ReneBogersREBO
ReneBogersREBO
Hi there,
Is it possible to feed a parameter in Project Information with a dropdownlist?
Reason I want this, is that modellers can choose (for example: mechanical / electrical) from the list and this should be populated in the Titleblock. I want this to have more uniformity in the title blocks, cause not everyone types is exactly the same.
For example: some use "mechanical - HVAC" | "mechanical - piping" and others use "HVAC" | "piping"
ReneBogersREBO
Anyone?
iainsavage
I've no idea if this would work for you but advice from a web search is to use a Key Schedule to pre-define available values - it seems to be more to do with families, no idea if it works for title blocks.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-create-para...
https://forums.autodesk.com/t5/revit-architecture-forum/family-drop-down-list-parameters/td-p/109086...
ReneBogersREBO
I already tried that out a bit, but didn't get it accomplished grmbl@#$@#
I don't think you can get them in the "Project Information" or I did not manage it
I will dive in it again this weekend I hope. Thank you! 😉
ReneBogersREBO
Morning,
I think this is not possible 😞
To add a key schedule, you need to select an Category. So it wont work for Project Information.
