Drawing code in material list
jackie_poonLMGLM
jackie_poonLMGLM
I recently received an inquiry from my colleagues at the construction site: They were asking about the possibility to include the conding that we give each component on a drawing of a ventilation system. To my knowledge, there are no such functions available by default on Revit families, but I'm entertaining the idea that a parameter could be included, where I can add the drawing code for each respective component and then include that parameter in, say, a schedule view. Any suggestions?
iainsavage
You could use the Comments or Type Comments field, or Description or Assembly Code or you could add your own shared parameter.
jackie_poonLMGLM
Thank you. The suggestion with the assembly code did the trick. I just had to add the assembly code to the schedule view, and everything else fell into place.
