We working with Geberit Silent-PP plug-in-system and therefor I downloaded the Revit Families from BIMObject and modified the elbow with lookup tables so that we can actually work with them. The angles are 15, 30, 45, 67.5 and 87.5° there is no problem to draw the first three ones but I couldn’t find a way to draw pipes with an angle of 67.5 or 87.5. In ACAD MEP you can switch between with the Tab key between the different dimensions this is not working within Revit. Or?
The angle under mechanical settings can’t be changed or is there a possibility to change those angles?
How can you draw a pipe system with this angles?
Regards
Do you have your units set to allow decimal degrees to round to more than one degree? Check your units settings.
See attaced picture and folow steps.
When you have specified elements (elbow and tee) you have 2 options:
1. Use any angles
2. Use specific angles
When you use standat families is better to use any angles - this will give you more perspective(fast) when you design pipe/duct network.
In other case if you use specific angles you tell to revit to use only angles in list below (see picture). This way guarantee precise work flow.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
