Draw Order
Draw Order
mwoodsonUUZVA
Message 1 of 11
Draw Order
mwoodsonUUZVA
I am working on a kitchen layout and need to display plumbing drains on a 2D sheet. When I place the drain symbol on the sheet, they look fine. When I print, the linework gets mixed up and SOME symbols are covered by the equipment they serve while others are not covered. In CAD, I could use the draw order option, but this seems to not be available in Revit. Any tips would be great, thanks!
Replies (10)
Message 2 of 11
ennujozlagam
when you print try/select raster processing and see if helps?
Message 3 of 11
hmunsell
couple questions:
  • is the equipment coming from a Link?
  • is it the same equipment each time covering the drains?
Howard Munsell
Message 4 of 11
mwoodsonUUZVA
I will try this tip today, thank you!
Message 5 of 11
mwoodsonUUZVA
The equipment is not from a link, I placed them in the model myself. The issue seems to be consistent with floor troughs, and grid lines.
Message 6 of 11
iainsavage
Post some screenshots please.
Message 7 of 11
mwoodsonUUZVA
Message 8 of 11
iainsavage
Are these two floor drains? If so, are they both the correct way up or is one of them upside down?
If possible please upload your model file or a cut down version of it so that we can open it and check settings etc.
Message 9 of 11
hmunsell
what would happen if you offset them so there raised just a little, just 1/8"?
or, alternatively, what happens if you Hide the floor?
Howard Munsell
Message 10 of 11
mwoodsonUUZVA
I raised them of the floor 1/8" all the way to 2" and visually there was no differences. I will try to hide the floor and see if that works.
Message 11 of 11
iainsavage
Please respond to my earlier post:
"Are these two floor drains? If so, are they both the correct way up or is one of them upside down?
If possible please upload your model file or a cut down version of it so that we can open it and check settings etc."
