Message 1 of 10
Hi everyone,
I'm facing an issue with Revit's View Range settings.
Even after setting the Bottom and View Depth to the same level with high positive offsets (as shown in the attached screenshot), the door still appears in the floor plan. My intention is to hide the door using the view range only — without using filters or hiding elements manually.
I expected that by raising the Bottom and View Depth offsets to 10,000 mm, the door (which is located lower) would no longer be visible in the view. However, it still shows up.
How can I hide the door using only the view range settings?
Any help or explanation would be greatly appreciated.
Thanks in advance!
