Hello Revit users ,
I creatd an annotation family with simple text of a number (1) in it, and I'v inserted it into another annotation fmaily with a hatched circle , then I took this family and inserted it into the final 3D spinkler family on its reference level.
after loading this final family into a project level , I couln't figuer out why the No-( 1 ) is not appeared , and I still see the hatched circle .
I tried many methods of family creation to show the annotation family with the text ( 1 ) in it !
I thought that might be somthing related to the scale of the project view level,
Thank for taking a quick look to the image , and to give me some hints arround this.
Have you all great day .
Solved by ToanDN. Go to Solution.
I can't load annotation tag family into a 3D family "the spinkler head" , gives me an unignorable message error.
How comes that in a lets say a simple family as a box and a text should be added on its reference level , after loading it into a project the text does not appear ?
All possible methods are done :
-adding the text directly in the 3D family , ----------- doesn't show the text in the project
-adding the text in an annotation template then loading it to the family ,-------- doesn't show the text in the project
-adding the text as a name tag in an annotation tag family then loading it to the 3D end family "which been refused "
Thank you for your support , my project is in Revit 2018.
After 2 days mashing out my head with this family , I just figuered out what makes annotation text disapears in the projects .
It is the scale .
It turns that I have to put the Number one the minimum size that Revit excepts 0.5mm then injecting it to the spinkler family reference level which is in scale 1/100 so it appears like this (image below).
But why I see three water connectors in the project even the other two spinklers heads are properly hidden .
