Design Options with MEP Systems
ray.blowersYGY6D
ray.blowersYGY6D
The dream is to have MEP systems and Design Options to fully play together.  Currently, there is a workflow of making a MEP discipline workset, then making a custom view template then associating the Design Option in the view template.
The challenges with this workflow:
  • It is time consuming to create all the worksets and view templates for the design options
  • You cannot fully connect MEP systems with this alternative workflow
  • Unable to do accurate calculations with the design
  • Issues with scheduling
  • If there is phasing with the Design Options, it becomes even more challenging
It would be great if there was a way to work with Design Options and MEP systems.  If there is another way, please share
Tom_Kunsman
I do think this is something Autodesk has worked on for the newer releases of Revit (2026 and 2025), so might be something to look into.
blank...
Design option are borderline useless even for architecture. Expecting something useful for MEP is probably asking WAY to much.
hmunsell
@Tom_Kunsman advancements have been made for Phasing, but I'm not aware of any for Design Options. I could be wrong though 🙂.
@ray.blowersYGY6D id suggest opening a post in the Ideas Forum for this topic 👍
Howard Munsell
HVAC-Novice
Design options in Revit are very schematic and don't work for MEP at all. None of the "I" works, like electrical load etc.
And maybe this is good. Because ideally I don't start to route pipes and ducts etc. before the architect/owner figured out what it is they want  🙂
We want 12 bathrooms and I pipe it all up, And now maybe only 8 bathroom. So I stop want I'm doing. Wait, now we want 12 bathrooms again, but all fixtures are at different locations. I don't want to incentivize architects to do even more of that 🙂
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
