Design file version comparing in Revit MEP
Message 1 of 10
Hi, I am aware of version comparison option of BIM 360. Do we have this option in Revit MEP? I would like to compare the Architectural, Structural, and MEP design versions in Revit MEP. is it possible? because I don't have a BIM 360. Does BIM 360 come with the separate cost? And, Can I compare the AECOsim design versions also in Revit MEP?
Replies (9)
Message 2 of 10
fabiosato
There is the compare model from Autodesk. It is a plug-in, you can find it in your Autodesk account manager page.
Fábio Sato
Message 3 of 10
I am unable to find the plug-in. please explain with more details.
Message 4 of 10
fabiosato
Go to your Autodesk account, select PRODUCT UPDATES, then search for REVIT EXTENSIONS.
Fábio Sato
Message 5 of 10
I did the same. but the page is blank and it doesn't search any Revit extensions.
Message 6 of 10
fabiosato
Try to use Desktop App to install it.
Fábio Sato
Message 7 of 10
I really appreciate your persistent replies. though I need more explanations. Can you please send the weblink of the 'version comparison' add-in? or please suggest any alternate ways to do that with more screenshots.
Message 8 of 10
fabiosato
The application appears in the taskbar, click on it to open the list.
It may be listed in this screen.
Fábio Sato
Message 9 of 10
Thanks, But it doesn't work like BIM 360 compare tool. See the video: https://connect.bim360.autodesk.com/bim-360-team-release-compare-changes-between-design-versions-and...
Message 10 of 10
fabiosato
You can´t do it in Revit, the option would be Navisworks.
Fábio Sato
