Delete Text Style
Delete Text Style
asommer
Message 1 of 35
Delete Text Style
asommer
Over the years of modifying Revit to suit our company, we had created and changed our text styles many times. Utilizing a "Template" file, we have a set of text styles we use on a typical basis. However, there are many other styles that no longer suit us, and I would like to delete them. I cannot seem to find a way to delete a text style. Any suggestions?
Replies (34)
Message 21 of 35
RobDraw
Thanks and goodbye.
Rob
Message 22 of 35
s.borello
**** right!  So many oversensitive people on here.  I greatly appreciate all your advice; you have helped make me much better at what I do.
Message 23 of 35
egorUMWM3
Stair Direction Tag might be holding one of these hostage as well. Let's add that to the list places to weed them out of.
- Legends
- Schedules
- Stair Direction Tag
Any others?
Message 24 of 35
EE_ING
Text styles are also used in:
Families > Annotations Symbols > "Automatic Up/Down Direction" and "Fixed Up Direction"
Message 25 of 35
levberez
It's Alive !!!
Message 26 of 35
fbernhart
That was it! Thanks so much!
Message 27 of 35
bim2.ntec
Thank you for your advice. It 's helpful.
Message 28 of 35
21a10004
And here i am, from 2014 to 2024, a decade later...
Looking for the EXACT SAME PROBLEM
Well for now. It seems for now, that the purge solved my issue
Message 29 of 35
ecT4PBM
Checking View Templates was very helpful advice and worked well for me, thank you!
Message 30 of 35
sascari
100% Rob is a troll. There is no way anyone is this dense. This is some next level pastime trolling. Rob, get a hobby.
Message 31 of 35
youssef.ibrahimM37J6
thank you @CoreyDaun this is very very useful
Message 32 of 35
RobertSZ3VF
Community Visitor
Community Visitor
this was very helpful. thank you
Message 33 of 35
thyen_039
Observer
Observer
You should write unnecessary text in a view, and then right click "Select all instances" > "In Entire Project Including Legend" and just delete it. After delete it all, find "Purge Unused" in "Manager", click "Check none" and then pick all text box, click "OK" (2024 version)
Message 34 of 35
Sleepingfish_Kuo
There is an unsafe solution.  With API tools can delete the Type (as elementId) directly.
All the Instances in document using this type will be deleted together.
And the Objects which using this text type as parameter value will be send another text type.
Message 35 of 35
dcrampton1
This is what I needed! Thank you.
