Default View Range
Default View Range
Default View Range
Is there a way to change the default value for the top offset of the view range? It is currently set to 7' 6" but I would like it to be higher. I know view range can be controlled with view templates, however that usually falls apart in projects that have multiple levels per floor.
Create a view template with view range you want and only tick that box. Apply it to any views you want then remove it or apply the permanent template (view range box left unticked) for those view. You can also set the system view type to use the view range template without assigning it permanently via edit type.
Thank you!
