Dcut Graphic representation
joaodossantos.pt
joaodossantos.pt
Is it possible to represent a duct or pipe with 3 lines: 2 solid and 1 dashed (pls see attach)?
debimmanager
Hi @joaodossantos.pt
See attached photo,
Thank you!!
Deivis E.
BIM Manager
joaodossantos.pt
Hi deproject07; Thanks for your quick answer.
That's work fine for straight segments; when the duct changes direction the fitting does not follow the graphic representation (pls see attach01).
Another question: I use 3 differents systems (Supply Arir, Return Air and Exhaust) with different graphical representation (attach02). How can i do that in revit?
joaodossantos.pt
I just figured out how to do with the 3 system types.
Thanks for your help.
Joao Dos Santos
debimmanager
Try this dude, and with click bottom right you have to apply colors with override graphics in view by elements.
Thank you!!
Deivis E.
BIM Manager
kadmonkee
go into your project browser / Duct Systems/ Supply Air right click select the graphic overrides button and define the properties for that system
Repeat the steps for each Duct System.
go into visibility graphics and set the centerline line pattern to your choice for Ducts and Duct Fittings
this will be the most consistent result for you regardless of which Duct System you are using and will allow you to switch out systems more easily.
keep in mind that this only works in Visual Style WireFrame
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
