Custom ribbon for dummies
Hi All!
Can someone explain is there a way to customize ribbon inside Revit? For instance, that you are able to rename panel, or remove some of the icons?!
rudi.roux
Duplicate of THIS THREAD
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
