Curved Model Edge not Displaying
lleblancSBBXJ
lleblancSBBXJ
See image below.  Can anyone help me get these edges to display correctly?  I've run into this problem with user-created families in the past and resolved it by using masking regions, but now I'm having the issue with pipes.  This only seems to happen in elevation or section views.
I tried turning hardware acceleration off with no success.  I'd really appreciate some input if anyone has suggestions.2022-06-01 15_44_40-Document1_ - Bluebeam Revu x64.png
lleblancSBBXJ
Well, I just found the article below.  It looks like this is being "investigated".
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Edges-of...
Sorry but I can't replicate.
Plan:
Section:
lleblancSBBXJ
@ToanDNThanks for the response.  It doesn't happen in all views, and I can't determine what causes it.  I have other views in the same project where this isn't an issue, but I've seen the issue in Revit 2021-2023.
iainsavage
Its usually because the pipe/fitting is not exactly parallel to the view plane, even being off by a very small fraction can cause this.
