Current calculation in electrical panel.
andreimorais
andreimorais
google translator:
"I am trying to get the correct values ​​of electric current per phase.
Basic settings:
Distribution System: 3 phases 4 wires 127 / 220V
Electric panel unbalanced, 3 poles; Voltage 220V; one column (custom panel table)
Revit 2019.
Circuits:
3 x 220V 5500W Showers
Current calculations (if performed correctly)
i = 5500/220 = 25A, the current is shared in two phases. as it is about three circuits, in a balanced situation we would have:
Corresponding phase 1: 25x2 = 50A
Current F2 = 50A
Current F3 = 50A
REVIT calculates the current per individual circuit perfectly, but it totally misses, changing the calculation method inexplicably, does anyone know a way around this problem? am I doing any incorrect settings?
fabiosato
Which option of load sum calculation are you using?
It is in the Electrical Settings.
Fábio Sato
andreimorais
Soma de carga aparente
"apparent load sum"
sragan
Revit's calculation is correct.   Voltages on different phases are out of phase or out of time with each other, so they must be added like vectors or phasors.
5500 W * 3 = 16500 watts.
16500/ (220* sqrt(3)) = 43.3 amps, the same as Revit calculates
