Crop View (Extents)
Crop View (Extents)
I am a revit user and i am facing a problem with Crop view. The Extent- Corp view is not highlighted in Properties. Therefore i am not able to change the view crop region
nathan.chapman
Make sure Crop View visible is checked in the properties of the view.  Also remember Crop View with have to also be checked for the view to be cropped.   If this isn't what your looking for can you please explain in more detail.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
You probably have a scope box applied to the view already. A few lines below the crop options in Properties, change the scope box to "none", then enable the crop options.
thanks Nathan,
that was really helpful.
