Creating a Parameter-Driven Directional Connector for a Revit Fitting Family
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All,
I'm currently working on a Revit Family project, specifically a fitting, and I've encountered some challenges that I hope this community can help with. My aim is to make the direction of the fitting's Connector controllable via family parameters. Ideally, I'd like to introduce two parameters, AngleX and AngleY, that would determine the Connector's orientation in relation to the X and Y axes respectively. Furthermore, it is crucial for these angles to operate independently of each other.
The primary obstacle I'm grappling with is how to define a parameter-driven angle between a 3D object (like an extrusion) and a plane, or even between two extrusions. While I've had some success manually adjusting the angle by selecting the object and altering the angle value, I've not had the same luck when trying to manipulate it via the family parameters (refer to the attached screenshot for clarification).
Attached is the family file that I'm currently working with, in case it provides better insight into my issue.
I would greatly appreciate any guidance or advice from those who've tackled similar problems or have expertise in this area.
Thank you in advance!
