Could anyone share the family of plumbing fixture
Could anyone share the family of plumbing fixture which is able to connected to the pipework.
thanks!
dzanta
most if not all plumbing fixtures are created with connectors so you can draw piping from those connectors.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
www.TechRoom.bg
Every family can be connected to system. Fist go inside family (with edit family) on menu create pick pipe connector and place it on some surface on family geometry. Fill connector properties - diameter . flow direction and etc and you are ready. Reload / replace the family in your project and now you can connect it to system.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
