copying air terminals goes without attaching
danezeq
danezeq
When i copy air terminals they placed without beening attached to the duct, when the duct has different size / height.
is there any way to multiple copy / array the air terminals while keep it always attached to the duct?
see video:
https://www.youtube.com/watch?v=x2naAGO478M
CADTripper
Use of array will always detach the air terminal from the duct connection and this is how Revit works at the moment, mostly the tapping to the main duct will get detached, and there's no other way you can keep them together using array and you have to reconnect them again one by one.  Use "Copy" instead of "Array", copying will keep the connections together.
Ryan Ortega
MEP BIM Lead
Aurecon Group - Dubai, UAE
www.ryanortega-bimportfolio.com
danezeq
thanks
1. How can i reconnect an air terminal?
2. i used "copy" and it cuase the air terminal to disconnect from the duct,
danezeq
anybody?
i dont know how to reconnect air terminal to a duct!
fabiosato
Sorry, wrong post, I can´t delete it
Fábio Sato
