Coordination Discipline: Missing Centerlines for Round Pipes/Ducts
goldack
goldack
Hi everyone,
I’d like to use the Coordination discipline because it displays all “general models” with color fill, which makes the view much clearer overall, and the pipe insulation also looks good.
The issue is: in Coordination, the pipe axis/centerline is missing for all round pipes and round ducts.
If I switch the discipline to Mechanical (Ventilation), the centerlines for round pipes/ducts show up correctly.
But then the pipe insulation doesn’t look good, and any transparency setting for the insulation also affects the pipe itself (as you can see in the screenshot).
That makes the insulation display look messy.
Is the only option to turn off insulation visibility and only tag it?
Has anyone had the same issue, or does anyone know how to fix it?
russellvee
The centerline should show up under Coordination when the Model Display is set to wireframe or when transparency of pipes is set >0. When it's set to hidden line, the outside of the pipe conceals the centerline of the pipe. Using the mechanical or plumbing discipline overrides this, making all pipes transparent to show the centerline and any hidden lines below.
lauri_barnhart
Hello, @goldack,
Did the information provided by @russellvee help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
