- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Were trying to make the jump over to Revit MEP but the issue is that we've invested many hours building hundreds upon hundreds of custom parts to use in our Plant 3D catalog.
Is there a way to convert a plant3d catalog into a Revit part family, or will we have to bite the bullet and rebuild these valves?
A few points:
1) standard specs (PVC, Carbon Steel, etc) might already be available from the manufacturers but sometimes the parts arent 100% accurate. Is it easy to adjust a random valve if its too long/short from the manufacturer/
2) one of the things i liked (and hated) about P3D was the spec editor where you could make dozens of custom fittings in a relatively quick fashion. Is there something similiar for revit where I can get create an entire pipe catalog by entering a bunch of parametric dimensional data?
3) we're investigating Fabrication CADMep as a go-between between plant parts and Revit Families, but I've read mixed reviews about using fabrication parts in Revit. What is the Revit community's consensus?
thanks in advance!
viet
