Controlling Schematic Representations
So... I have some fittings that do everything I want them to.... save for the single line schematics.
The attached flange is an example what I am having a hard time wrapping my head around.
In a coarse 3D view, the 2D representation lines appear the way I intended but in plan or elevation views, there is clearly some scaling going on.
Is there a way to control that scaling?
I have tried constraining them with parameters and that seems to do nothing.
nathan.chapman
if you don't want the scaling then within the family go to family types and uncheck Use Annotation Scale.  Now if you want it then within the projects MEP setting you will notice a Pipe fitting Annotation Size.  That will adjust scaling.
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
