Control center of cylinder - wall based family?
LjubanL
LjubanL
Hi to all,
I have one question regarding to position of cylinder on wall.
So I create one generic model (wall based) and create one parameter from center of this family:
And then import this family to project:
But my parameter can’t control center of this cylinder?
Some control can be achieved with build in parameter elevation from level – but its not correct?
What am i doing wrong?
Please find gif in attachment and also revit file..
BR
Ljuban
Replies (12)
hmunsell
place a reference plane and lock the circle to the reference plane. then add a dimensional constraint to the reference plane.
Howard Munsell
fabiosato
If you edit the extrusion sketch, select the circle, and in the properties check SHOW CENTER MARK, you can use it to lock to the planes and even create a dimension from it.
Fábio Sato
LjubanL
I locked circle in family and everything works in family... problem starts when I try to position circle in project (on wall)
BR
Ljuban
fabiosato
Can you share your family for inspection?
Fábio Sato
LjubanL
Yes, please find in attachment revit file & family.
BR
Ljuban
fabiosato
Try this family; you can use Elevation From Level to control its position.
Fábio Sato
LjubanL
I load your family and you say that I can control position with elevation but its not correct elevation when I measure:
When you measure in your revit from the center how much do you get? is that value 1500mm?
BR
Ljuban
fabiosato
So you need to control the position AND the dimension reference? Where is the reference for dimension, bottom or center?
Fábio Sato
LjubanL
Hi Fabiosato,
Center like in the family:
BR
Ljuban
fabiosato
I reviewed the family, and including a horizontal reference plane was very important.
Fábio Sato
LjubanL
Now it works.
What was the secret, what did I do wrong?
Thank you very much for your help.
Really thanks...
BR
Ljuban
fabiosato
As I mentioned, in the elevation view, a reference plane aligned to the reference plane was missing.
Fábio Sato
