Connector Numbers of Mechanical Equipment
Message 1 of 11
I created a mechanical exhaust fan with four connectors for testing something else.
The interesting is when I was creating a system, revit asked me which connector I wanted to use. In the list of connectors, it looks like each one has its own connector number (connector 4 to 7).
Can someone tell me where is this parameter saved in revit family and am I able to change that?
Thanks for any comment!Cat Happy
Replies (10)
Message 2 of 11
fabiosato
Do you have any other type of connector in the family, usually they are numbered after the placement sequence.
To include a text use the description parameter of the connector properties, will make your life easier in this selection window.
Fábio Sato
Message 3 of 11
robert.klempau
Hello @Anonymous,
I created a Video for you where I show you what to do when adding connectors of the same System classification to your family.
@fabiosato is right.
That you see only connector 4 till 7 and not 1 till 4 can have several reasons.
  1. There are other connectors in your model like Duct, conduit, cable tray or electrical connectors in your family.
  2. There are connectors in your family but you removed some of them.
In your case I see 4 Duct connector and 1 electrical connector.
Don't worry about the Connector Numbers.
As @fabiosato mentioned, add the description to the connector so you know exactly which connector is which.
See my video below.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 4 of 11
Thanks rklempau,
You are right. There is an electrical connector. Besides it, initially there were two duct connectors and I removed them, then I added four duct connectors. That explains why my duct connectors in the dialog starts from "4".
However, if two initial duct connectors had been removed, why the current duct connectors start numbering from "2". Does it mean these two initial connectors are still in my family? Do I need to find out them and delete?
Message 5 of 11
robert.klempau
Hello @Anonymous,
When you add a connector to your family, Revit will give it a number.
That connector always keeps that number.
If I am correct, and I will ask @jeremytammik:
When you remove the connector Revit will remove also that number.
Revit will no use the deleted number again.
Every new connector gets the highest connector number in your family +1.
So a removed connector will stay unused.
I used the Revit Lookup Tool to have a deep look in the Revit family and there you see that there are only the connectors that are present in the family.
My conclusion:
When removing a connector, it will be removed permanently and it will not reuse that connector number again.
Note: The Snoop DB (Revit Lookup) is an Add-In I use to look directly into the Revit Database. Please see:
Revit 2016: click here
Revit 2017: click here
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 6 of 11
jeremytammik
Checking with the development team for you... hang on...
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 7 of 11
jeremytammik
I talked with the development team, and they say:
Checking the code, there is one key function to get the “Connector number” in edit family environment:
  int ConnectorElem::defaultIndex()
    for(elemIter.initIter(); !elemIter.isDone(); elemIter.increment()){
      pElem = getDocument()->getElement(elemIter.getElementId());
      if (!pElem){
        continue;
      if (IS_A(ConnectorElem, pElem)){
        pConnectorElem = downcast<const ConnectorElem*>(pElem);
        nIndex      = pConnectorElem->getIndex();
        if (nIndex > nMaxIndex){
          nMaxIndex = nIndex;
    //We want to start the indices at 1 if there are none.
    if (nMaxIndex <= 0){
      nMaxIndex = 1;
    else{
      nMaxIndex++;
    return nMaxIndex;
The index that you refer to as connector number is serialized with the ConnectorElem, so it remains unchanged once the connector exists.
Based on the above implementation, we can draw the following conclusions:
  • The index starts from 1. In some old family, we found the index is from 0, caused by old code.
  • The newly created connector index is the highest index + 1.
  • The index might not be continuous. If you removed an 'inner' connector whose index is in [1, maxIndex), maxIndex is kept, so the index will be skipped.
  • The index might be reused, if user removes all indices in [index, maxIndex].
So, to answer your questions:
  • When you add a connector to your family, Revit will give it a number. [Yes]
  • That connector always keeps that number. [Yes]
  • When you remove the connector, Revit will remove also that number. [Yes]
  • Revit will no use the deleted number again. [No]: If you removed the maxIndex, and the maxIndex will be reused.
  • Every new connector gets the highest connector number in your family +1. [Yes] So a removed connector will stay unused.
  • I used the Revit Lookup Tool to have a deep look in the Revit family and there you see that there are only the connectors that are present in the family. [Index is one serialized parameter of connector element, but it is not visible to user]
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 11
robert.klempau
Hello @jeremytammik,
Thanks for your splendid answer. Smiley Happy
It confirms what I thought.
@Anonymous,
Was this enough info for you?
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 9 of 11
jeremytammik
Dear Robert,
Glad you like it and thank you for your appreciation.
For better readability and future reference, I added it to The Building Coder blog as well:
http://thebuildingcoder.typepad.com/blog/2017/02/revit-mep-connector-number.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 10 of 11
Thank you @jeremytammik!
Thank you @robert.klempau!
So busy these days. Just read your answers. My doubt is cleared up.
Message 11 of 11
I understand that how this value comes to be, and that it is unchangeable. However, I don't understand why this value is unchangeable, or even shown at all. Couldn't it just show "Connector" and then the description? It can get confusing if you would like to use numbers in the description and then they conflict with the connector number.
