Connector element will not output correct flow
Message 1 of 11
I've been struggling with this issue for some hours now and I could not simply find out how and why the connectors I added to my object will not output the correct flow. I have added 4 pipe connectors (2 in, 2 out, 2 hydronic supply ,2 hydronic return) and when I specify Flow ( Flow Configuration being set to preset) manually to each connector, it will not appear correctly when loading into the model. Either the return pipes have same value and supply has 0 flow, or other strange combinations...
Therefore I cannot size my pipes since there is no flow or incorrect value going out or in from my object.
Thanks!
Replies (10)
Message 2 of 11
RobDraw
It is very hard to see what is going on from those images. It looks like the upper images are from the family editor but the rest of the content seems to show a piping system. The text is too small to read...
Clarification or, even better, the model is needed for any meaningful response.
Rob
Message 3 of 11
If you click the image and CTRL+wheel you can zoom in and see the images more clearly. But anyway I have attached the Fan Coil Unit family object here. You can add it in a new project and try to draw the 4 pipes exiting out of the object and see that the flow that is set in the family is incorrectly outputted withing the model.
Thanks for your support !
Message 4 of 11
RobDraw
Of course, I already tried that. The resolution is too low to read the text.
I'm having trouble figuring out what the problem is. I'll take another look later after my coffee kicks in.
Rob
Message 5 of 11
dmiller_SCE
Why is there a .06 flow difference for the total Return vs total  Supply for the equipment connectors?
Message 6 of 11
I tried to figure out which pipe has which flow thinking that maybe there is an error between the connector “hydronic supply/return” setting in the family editor and the fact that I have my own sub-systems set up in the model (ex: CHW supply/return under Hydronic supply Systems and same for HW). I tried to put equal supply-return values for Hydronic supply and return for my CHW sub-system pipes and same for HW, but to no avail. Same issue happened, values are either 0 displayed or simply randomly distributed among pipes. (there should be actually only two values: for CHW pipes/connectors return=supply=say 0.26 l/s and HW ret=sup= say 0.06 l/s).
Thanks for your replies!
Message 7 of 11
dmiller_SCE
Ok. All you need to is Link the connectors together. Link One supply to one Return to propagate flows.
Message 8 of 11
dmiller_SCE
see screencast. You need to tell the family which connectors belong together by linking them. Also, I would create additional parameters to control the flow of the family within the project. I only showed you how to link the connectors in the screencast.
Message 9 of 11
Thanks a lot !! You're a lifesaver :). It works now. I also managed to figure out how to add parameters in the project by adding parameters in Family types and setting them to "Instance" so they appear under properties.
Message 10 of 11
Iev60047
Looks like your post was marked as the solution - but your screencast is no longer available. @dmiller_SCE would you be able to re-upload the screencast by chance? Or does someone else have the answer to this problem? Thanks!
Message 11 of 11
iainsavage
Do you mean to link connectors? Select one, on the ribbon select Link Connectors and then select the one that you want to link to.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-ED50E6C8-F71C-4AF8-AB4B-113A93C3F541
BUT note from that help page that "Linked connectors only have an effect when the System Type is set to Global, which is common for fittings and in‐line components such as dampers, valves, and pumps"
For other categories of connector you need to create parameters of type Flow and associate each parameter to the correct connectors.
