Conduit surface connector issues
sragan
sragan
I wanted a conduit junction box that could have 2 conduits come into one side, and one out the other side.
So I took Revit's standard conduit "tee", and edited it and saved as a new family.   I removed all the individual connectors, and replaced with surface connectors.  However, it doesn't act quite right.
If I try to connect a conduit dead center to a side, it never connects.  If I try to connect one off center, it tries to open the surface connector placement view, but that never opens.  Revit just seems to be stuck in a loop until i hit enter, and then it places the conduit.
I thought maybe this had something to do with the sizing of the box (which it seems to get from the conduit sizes using a convoluted calculation).   So I removed all that nonsense and just made the box 12x12x6.   But it still has the same issues.
Family attached (Revit 2023).
iainsavage
sragan
It's very iffy, but eventually seemed to work.
I changed it to a electrical fixtures, and changed the category to a junction box.  Still did not work.  also tried Elect. Equipment, and Panelboard.  Still no.   Deleted connectors and reinserted conduit connectors.   Still no help.
So I put a connector on top, and change the view, and tried to draw a vertical conduit (like I would from a panel).   Suddenly everything started working.   Including a family that hadn't worked, but suddenly does work.
Anyhow, seems to work now, and I can confirm changing the family to Conduit Fittings breaks it again.
